OBielegend
Hi I'm new to this forum but I have a Question.
I have a AMD FX 4170 Cpu(4.2Ghz).
When I was about to try to Overclock it I noticed that its
Current speed was higher that its target speed when I maxed out my cpu usage with Prime95.
Target speed is 4200mhz
Current speed is 4551mhz
I have not overclocked in any way I have also set my cpu setting's to default
and turbo control is deactivated.
My pc is stable and game's run just fine.
I would just like to know why it does this and if there may be a problem.
http://www.fileswap.com/dl/pFYp2J6e/Overdrive_proof.jpg.html[/IMG
pc spec's
AMD fx 4170 4.2Ghz
Radeon HD 7870 2GB Ghz edition
Corsair LP vengeance 1600mhz(2x4GB)
Seasonic S12II 620W power supply
Sorry that it is a new thread, I looked but couldn't find anything similar
Thank you;)
pc spec's
AMD fx 4170 4.2Ghz
Thank you;)
