cue/bin -> iso??
JavaMomma
701
a friend just sent me a cue/bin image file, i dont want to install CDRWIN, is there anyway i can change this into another file format for burning?
i'm using NERO & CLONECD
Thanks.
RacerX
873
you could use ISObuster to open/install it, but what's wrong with CDRWin? I have Nero & ClonCd installed too so what's the big deal?
mrfroni
11
you can use fireburner to burn the .bin. just load up the cue file and you will have yourself an image :)
nippyjun
8,447
My favorite program for converting Bins to Iso's is Binchunker. Works fast and works good. Check it out.
Noriaki
13,640
I'll second nippyjun's vote for BinChunker.
I used to use it to convert .bin/.cue to ISOs (I bought a CDRWin licsense recently and use it alot, but I use to use BinChunker)
