[Edit: Fixed the problem...will take a while to figure out exactly why my change fixed the problem, but oh well...]
Taking a stab at learning html, and I'm up to CSS style sheets.
I'm trying to make a 3 column webpage with links in the left and right column and basic text in the middle.
I've got the left and middle fine, but can't get anything to show up in my right-hand column. Stangely, the only time I can see the links in the right hand column is when I am manually changing the size of the IE window....making it smaller by clicking the edge of the window and dragging. While I am resizing the window, I can see everything that I expect to see, but as soon as I stop resizing, it disappears again.
Also, when I mouseover where the links should be, the cursor changes to a hand and the link shows up in the bottom info bar...the links works. I just can't see them. Can't highlight them with the cursor. Ctrl-A doesn't highlight them either.
Anyone have any suggestions?
