Alright, after fixing the CS (1.6) problem with my linksys router I now face another problem. I started something like a bot match to try out the game (first time playing it) and I then quit that and went to join a real game with real people. It then hung...for a LONG TIME. I hit ctrl+alt+del and all the other junk. Tried alt-tabbing out even that didn't work. EVENTUALLY (after a couple of minutes, maby a little less) it finally desides to do something and it then proceeds to load the level and join. This also happens inbetween matches too (when going to another map).
Also, with use of my shiny new G15 keyboard I noticed that it was 100%CPU the whole time it hung up on me. I knew it might be doing something since the %ram kept on changing, it would go up, jump down and then slowly go back up.
Now, is this normal? I have Athlon XP and 9800XT video card if that helps.
And I give
to anyone that helps.
And I give
