CS dont work with my new rig kt7a 1ghz amd please help in WinMe using gts 2
bonkers325
13,076
tried official nvidia drivers and 2 more 6.67 and 6.47 no go
using gts 2
via 4in1 4.28 tried and 4.25 also
using the 3.011 ide drivers
using winme
need help cant play CS
kt133a abit kt7a @1ghz real 1ghz
clocked or no clocked same crap bios untweaked or tweaked same crap
hellllllllllllllllllppppppppppppppppppppp :(
RobsTV
2,520
What is it exactly doing?
If it gives you garbage on the screen, hit escape to go to menu, then resume.
Mem
21,476
13
bonkers325,what`s the exact problem?I play CS with no problems on my MSI K7T Pro(4.28 drivers) & Geforce2 MX(6.50 drivers)using Win98,so I would like to know exactly what the problem is you`ve. Btw what version of Half-life & CS are you using?
Mem
21,476
13
I know CS runs fine on WinME since AMB our Member here is always playing it,so try disabling everything running in the background,I had one game awhile back that would not run with certain programs running in the background,next make sure you have latest version of Half-life(1.1.0.4) also if you are using the Beta version of CS upgrade to the latest version.
You could try also uninstalling the game & reinstalling it,see if that helps.
Killrose
6,230
8
Are you trying to use the on-board sound? Or do you have an audio card. I had some problems with the onboard sound, and just put my Aureal card back in.
