CS dont work with my new rig kt7a 1ghz amd please help in WinMe using gts 2
bonkers325
13,076
tried official nvidia drivers and 2 more 6.67 and 6.47 no go
using gts 2
via 4in1 4.28 tried and 4.25 also
using the 3.011 ide drivers
using winme
need help cant play CS
kt133a abit kt7a @1ghz real 1ghz
clocked or no clocked same crap bios untweaked or tweaked same crap
hellllllllllllllllllppppppppppppppppppppp :(
Zeeliv
1,213
"don't work" and "can't play" aren't the best descriptions of the problem for people to try to help ya man. Get more speciffic:confused:
AmazonRasta
Banned
Dec 2, 2000
2,005
Maybe a corrupt installation file? Try uninstalling/deleting all of Half-Life, re-installing, then download and re-install Counterstrike as well. Hope this helps.
GT1999
5,261
Had a friend with the same problem. He formatted his drive to NTFS, installed Win2000 and it's working fine now. Go figure.
bonkers325
13,076
intel box works fine changed to a amd box wam :(
btw enlight case with enlight 250w psu
768/0 error of some sort
dont know
man
wierd
divinemartyr
2,439
I recently had a similar problem when playing ANY game on my system, the problem ended up being a bad stick of ram. I even tried ram testers like those found here but even that didn't find the problems. I stuck in different RAM and never had the problem again. I just called Crucial and got an RMA on the old RAM, waiting for it to show up now.
dm
divinemartyr
2,439
Just thought of one more thing, did you make sure the RAM you were using in your old system was compatible with VIA chipsets?
dm
Mutilator
3,513
10
You might wanna look at upgrading that PS to 300W AMD approved :)
That's what I had to do when I got my enlight case... and I'm only running an Athlon 750.
bonkers325
13,076
i thought of the psu maybe i will try to play on my 300w amd approved psu first then see
ram is good infineon was using on intel box worked 100% fab
SiliconVandal
Banned
Nov 17, 2000
786
I 3rd the ME Sucks petition. UGh :/
I would try deleting HL and taking it out of the registry, and re-installing. Also, if you do not have the latest patch, you need it (of course..especially for CS..).
SV
