Try installing the direct proper mouse drivers for your mouse. I've run XP for quite some time, and as long as I install the MS Intellimouse Explorer drivers, it operates just as it does in Win2k.
i did that... i have a Logitech wheeel optical... tried installing the latest logitech drivers.. no good... then i tried the MS drivers... it was better... still no good.
