crysis beta problem
kevinf2090
684
i just got a x1950 pro to upgrade my old 6600gt. even on lowest settings, i would see yellow textures just pop out. i thought that the x1950 pro can at least play it at medium settings and perfect at low settings. is it just because this is a beta. will it be fixed in the final version
schneiderguy
10,763
31
The yellow textures go away after a couple minutes of play. I think it loads them as they are needed.
kevinf2090
684
so is this caused by a weak video card or will the problem go away once the final version releases
Bibble
1,293
I had yellow textures the first few times I played, but I never see them now. I'm using an 8800gts. I'd bet the problem will go away by the time the game comes out.
pontifex
43,806
44
I had them too when I played, but the game sucked so bad that I uninstalled it after about 30 minutes so i didn't care.
SOSTrooper
2,552
Yah I had that problem as well, and I have an 8800GTS. So it's not a video card problem.
Ryland
2,818
13
What was bad about it?
pontifex
43,806
44
bf2 clone, players are extremely small unless you are right on top of them, takes too long to walk/run between points, ran like crap even with all the settings set to low.
Ryland
2,818
13
That was in multiplayer mode, right? Have they released the single player beta yet?
pontifex
43,806
44
yeah, MP only. i don't think there is a SP demo out yet.
Coldkilla
3,944
You will notice that when you play the first few times the level isn't completely loaded. You must continue play with these malfunctions in order to give it a chance to fully load. Then you will no longer have this issue, even after system shutdown.
To Ponti: SP Demo is out on the 26th along with modding tools, map editor (Sandbox2).
Thread starter Similar threads Forum Replies Date
aigomorla PC Games 15
H PC Games 0
ASK THE COMMUNITY
