Cryptocoin Mining?
Page 417 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Mark R
16
Lol.There's something seriously wrong with teh coin.
The difficulty isn't adjusting. Difficulty is stuck at 1 - should be at least 30.
The coin will be mined out in a couple of hours at this rate.
IEC
14,441
5,434
I quit bothering with AKC. Even once solo mining was working "properly" none of the blocks I found were getting credited to my balance. Moved back to Max which is enjoying a bit of a resurgence... talk about irony.
Geared up for solo mining PandaCoin later.
geokilla
2,012
Is Vertminer the only one working for Pandacoin when it launches? Do I have to spend 2 hours trying to get it to work again? Lol.
IEC
14,441
5,434
I'm irritated beyond belief. This coin daemon is a piece of shit.
If it makes you feel any better the wallet is a piece of excrement as well. I supposedly mined three blocks only to have them mysteriously vanish into the ether.
frowertr
1,371
41
Rav3n just added AKC to his P2pool fork for anyone wanting to open a public node.
At this point the whole release was a disaster. Im not sure its worth any more aggravation.
SunnyD
Belgian Waffler
Jan 2, 2001
32,674
www.neftastic.com
Well that's explainable - you mined orphan blocks. Basically you mined them, they get credited, but then while they're getting confirmed the network realized someone else found them before you and took them away. That's normal.
My issue, it's almost as if the network wasn't even recognizing any work done by the pool. I know it wasn't a firewall issue, I know it wasn't an orphan issue, and I know it wasn't a sync issue because I monitored all of that as things were happening.
I'm going to look into it a little bit more this evening, then if that doesn't clear things up I'm just going to delete the pool. (Not like it matters, the damage is already done)
KlokWyze
4,451
9
www.dogsonacid.com
1 of my cards doesn't submit shares. It only submits blocks.... lol it's just a single 7790. The pool is detecting the miner, but I doubt it's doing anything. Anyone ever have this problem? What exactly is going on?
Mark R
16
BLOCK! means that you successfully mined the coins (*), and what you submitted wasn't just a random share.
(*) assuming that the block actually gets accepted into the blockchain.
KlokWyze
4,451
9
www.dogsonacid.com
yeah. doesn't look like they are .... lol
might as well just solo mine if I have a 100% success rate @ finding blocks.
Mark R
16
Did you solo mine some coins? Any exchanges taking it?
Solomined 280k in the time it took for SunnyD to put his broken pool up. Spent an hour scratching my ass on that pool, before giving up. Would have got a lot more if it hadn't taken me 7 minutes to realise I hadn't opened a port on the firewall between my mining subnet and the PC with the wallet on it.
Unloaded about half of my coins privately for 0.1 BTC. Will probably aim to get rid of the rest tomorrow or over the weekend.
