ASUS P5W DH Deluxe, Intel Core 2 Duo 6600 2.4 GHz 1066MHz FSB, 4GB DDR2 800 limited to 3.2GB due to Windows Vista Ultimate 32-bit.
I have 4 sticks of Crucial Ballistix 1GB DDR2 800 (PC2 6400) CAS 4-4-4-12. In the mobo BIOS , everything is set to auto and system is stable but I noticed that memory is running at DDR2 667 (PC2 5300) CAS 5-5-5-18. When I change the settings to manual; CPU frequency 266 MHz, DRAM frequency 800 MHz, CAS 4-4-4-12 tWR 6, Memory voltage 2.2V, CPU core voltage 1.35 V. I get BSoD with many kinds of error like BAD POOL HEADER, IRQL NOT LESS OR EQUAL, etc.
Right now everything is set to auto except for CAS, so I'm running at DDR2 667 speed CAS 4-4-4-12, system seems stable.
Do I have bad memory? I'm thinking of getting a different brand to see if system will stably run at DDR2 800. If it doesn't, it's probably a mobo limitation though the manual doesn't specify it.
