crucial ballistix ram problem
stag3
3,623
so random blue screens and finally
failing to load the os even in safe mode
i have 4x1gb ddr2 6400 sticks
my question at this poinjt
3/4 sticks do pass memtest and hci memtest
do i just rma the 1 bad stick?
or the pair that was sent to me last (matching pair)
Elixer
10,371
762
Do you run memtest after installing? What voltages / timmings are you using?
If they came as a pair, then I would RMA the pair.
stag3
3,623
i took all 4 sticks out, then put 1 stick in at a time and ran memtest for 1 hr
found the 1 bad stick
i then put the remaining 3 sticks in leaving the bad 1 out and ran memtest over night
no issues
i then loaded HCI memtest within windows and let it run over 100% coverage
came back with 0 errors (with those 3 sticks)
stock voltage, timing cas 4-4-4-12 @ 2.0v
never overclocked
i have already contacted crucial for an rma on the bad stick
i think i will be moving to 2x2gb sticks now.
legcramp
1,671
113
These die a lot, I had 2 sticks and both ended up dying at different times, did not bother to RMA them anymore as they would probably die again.
Gillbot
28,830
17
last time I contacted crucial on a suspected bad stick out of 4, they told me to return all 4 of them.
Your best bet is to contact crucial and see what they say.
stag3
3,623
yea just contacted them, they said 1 stick is fine, no need to send the other 3 or matching set of 2
Elixer
10,371
762
I dunno, if I bought 'matched pair', then I would want a 'matched pair' returned to me.
Otherwise, what is the point of paying more for the 'matched pair' ?
betaflame
I've had so many crucial sticks die it's not even funny. a 1066 pair died 3 times (RMAed 3x) and an 800 pair died twice(also RMAed 2x)
stag3
3,623
i was wondering that myself but he said the only ones they make are all spec'd the same @ 2.0v and it won't really matter as far as compatibility is concerned anymore
stag3
3,623
There is none if the kit price is higher.
kit price was actually cheaper, i think i paid 25 for the pair from frys
