CRTs are bad for your eyes!
us3rnotfound
5,334
Originally posted by: thomsbrain
i used to run my old CRT at 100 Hz. having a quality monitor goes a long way towards a sharper image, reduced jitter, and the capability for significantly higher refresh rates. the only reason i switched to LCD was they don't make laptops with CRTs. anyone who complains that CRTs flicker are either using a crappy monitor, are too ignorant to adjust their display settings, or both.
Hmm..They don't make laptops with CRTs? :confused:
Feb 19, 2001
20,155
23
Originally posted by: Alone
Originally posted by: StrangerGuy
Originally posted by: intogamer
Just found out that CRTs are bad for you eyes. Because it flickers. Your eyes will take it but your brain won't!
I'm upgrading
I bet 99% of the populace who says CRT monitors sucks compared to LCD is because they didn't bother to set the refresh rate above 60Hz.
Colors are better on a CRT, in my opinion. Mind you, the refresh rate might seem alright when you're using it (I had mine set at 80-85) but when you (I) switch(ed) to an LCD, there's a noticable difference and it's hard to go back.
Uhh I hav eone of the best 17" flat CRTs out there. Samsung's NF700. Ever see that glass, it's like a freakign bullet proof glass or osmething cuz it's so thick. Yes I get a maximum of 116 hz @ 1024x768, but the recommended is 100, but seriously, 85 is not even enough. That's why I never ran at 1280x1024 because the recommended was 87 hz..
Colors rock, but I'l ltell you I take my LCD over that CRT anyday. And if you buy crap LCDs like Dell's 2405 then yes... you will say LCDs suck.
