CRT Monitor question-leave it on or turn it off?
gcmmia
8
Just got a new 19" Dell P992 Trinitron (aperture grill) to replace my burned-out 7 year old monitor.
It is used on a PC that is on ~ 18 hours a day. To achieve maximum lifetime for the monitor
should I turn it off each time someone leaves the PC, or just leave it on in either screensaver or
auto shutdown mode? Electricity useage and heat output are of no concern for this location,
only longevity for the monitor.
Thanks in advance.:)
kurt454
773
If I do not use mine for several hours, I shut my monitor off(computer is left on).
xSauronx
19,582
4
if im gonna be gone for hours (work, sleep etc)
i cut mine off
otherwise i use a screen saver for about 10 minutes, then ive got it set to power saving....cause im too lazy to hit the power button :)
BFG10K
22,709
3,003
Use standby mode - it'll save the tube without turning the monitor on/off. And don't use screensavers.
I have mine set to activate after 15 minutes of inactivity.
