Updated:
The solution was to Use CCC's OverDrive and i had to *Fool* CCC with 2 alligator clips and some wire - attaching each clip to the "extra" uncovered 2-pins in each 8-pin connector and grounding the wire. CCC then set everything up OK and we settled on a [for now] core speed of 697mhz [up from the Pro's 506 but down from the XT's 743] and memory at the XT's stock speed ... about +30% increase ... 3DMark06 increased from 10500>13090 and some DX10 games became "playable" ... and it looks like a "keeper'
Many thanks for your assistance and suggestions
My rig is in Sig ... my P35 MB has a 16x and a 4xPCIe slot
i have a 2900xt 512-bit/512 MB [in the 16x slot] and a 2900pro 256-bit/512MB in the 4x slot and am attempting to CrossFire them. i now have 2 Interconnect Bridges and i have the extra Power to the MB for Xfire connected, 2 PCIe connectors - 1 to the 2900xt and 1 to the 2900pro and a 2nd molex to PCIe cable into the 2nd connector of the 2900xt. i have also switched cables around to make sure one rail is not overloaded. Everything looks fine with voltages.
The *problem* is that when i go into CCC i see a "!" ... and read "Your system is not functioning at optimal performance. Please go to the diagnostics page for a more detailed analysis." When i go to the diagnostic page there is *nothing* noted.
"Enable CrossFire" is checked ... BUT when i look at the "Graphics Adapter:" all i see is "1. ATI Radeon HD2900XT [Synch Master] ... no 2nd GPU
- it does show in "System Information" 2900Pro is on IRQ 429496293 and the 2900xt is on IRQ 429496293 both with "OK" status. And it is the same for Vista 32 or Vista 64. i have uninstalled and reinstalled 2 sets of drivers 7.12/8.1 with the same lack of results.
*Worst of all* ... my 3DMark06 score [representing how little performance increase there is with it "enabled"] only went from 10500 marks to 12500 marks. And to add insult to injury, i can't OC it ... not Riva Tuner nor AT tray tools nor AMD GPU Clock tool. Of course i am also using the latest betas as the certified ones are old. i see no settings for games or 'profiles' to enable.
So i figure i am doing something wrong ... It *should* work. Well, it IS working ... but clearly - at present - it is not much of a worthwhile performance increase.
http://ati.amd.com/technology/crossfire/charts.html
if all i can get is 15% improvement ... 2900pro is going back to NewEgg for refund ... i am quite satisfied with a single 2900xt for DX9 games.
