- Nov 10, 2007
- 15
- 0
- 66
I have 2 4850s (both not similiar and also non-reference pcb design). One is Diamond (GeCube) and the other is HIS. I am running windows 7 (7100) x64 and using Cat 9.5.
Whenever I try to run a full screen game w/ crossfire enabled, it starts flickering on both screens and crashes, or it simply crashes.
W/ crossfire off, it works fine. W/ the 2nd monitor disabled and crossfire enabled, it works fine.
Crossfire is working fine. I tested it using 3d vantage and cod4 and there is much higher score / fps with crossfire on.
Some side things to note are:
The Diamond card came with a bios in which the crossfire tab didn't show up in CCC, so I had to downgrade to early bios to fix that. I am only using one xfire bridge connector, the one closest to the end of the card. This is because I only have one ribbon cable and both cards have accelero S1 coolers, making it very hard to connect the inside bridge.
Also using Display Fusion for 2 seperate wallpaper functions across both monitors, but I turned off this app and still got the problem.
Is this already a known problem or seems to be an isolated case?
