Cross Platform Programming Language with GUI interface...?
Atheras
63
I'm in the design stages of a program that I'd like to be able to have cross-platform capability, but I'm not sure what my options are for the programming language. I'm experienced with Visual Basic, but that's obviously not a cross-platform language (even if it is powerful enough to do what I want). I've programmed very limited in C++ and Java, but knowing the language isn't the problem (I can overcome that).
What's .NET like? I was reading another forum post that was debating Java and .NET and a few people were referring to .NET as "Java done right" and that it was capable of cross-platform? Is this true? (And if so....which section of .NET? If I'm not mistaken there's .NET versions of all of MS popular language programs, as well as C#?)
Basically what I'm looking for is a programming language that you can design a GUI in while allowing for powerful cross-platform capability. If anyone can make any suggestions as to what to use, and why...please do so.
Atheras
singh
1,449
JAVA's the only option for "above average" cross-platform capability. But, the GUI won't look too nice unless you're willing to put in a lot of work.
Atheras
63
Alot of work? That shouldn't be too much of a problem really.
Anyone have any recommended reads on Java programming? As I've said....I've messed with it a little, but nothing as far as GUI goes and little more beyond "Hello world" style apps. Any sources would be much appreciated.
Atheras
glugglug
5,340
Depending on how you look at it, C++ is cross platform. (You can get a C++ compiler with all the standard libraries for ANY platform pretty much.) Certainly more "cross-platform" than .NET
wxwindows provides some good libraries for handling the GUI, giving your program the appropriate look & feel for whatever the target (Mac OS, Win32, UNIX/XFree, etc). Or so I've heard. Haven't worked much with it myself yet.
kylix is C++ Builder ported to Linux. (Delphi with ability to handle both Pascal & C++ units) That is your #1 choice if your targets are Linux & Windows. Its not available for Mac, at least not currently. The visual development environment and related libraries in Delphi/C++ Builder totally blows away VB or anything else M$ has to offer, even if you have no cross platform plans.
Another option is J++ Builder (java-based version of C++ Builder). The "compiled" code it generates will run in the JVM for any platform's version of java, but the performance won't be near that of C++.
m0ti
975
glugglug,
I've tried wxWindows, looks nice, but I can't get it to compile under vc7. And I don't want to install vc6 to get around this. Know anything about it?
_____________
Java is currently the only thing that's cross-platform "out-of-the-box" (well it doesn't have a box, but you know).
Yes, .Net does "fix" some things in Java (i.e. makes them more comfortable) though there a lot of libraries out there that provide fairly similar functionality on the Java side.
Best book for intro java is Bruce Eckel's "Thinking In Java" Do a search, you can turn up the PDF without a problem (it's distributed that way. You can also buy the print version if you want).
Atheras
63
Thanks for all the info guys.
m0ti: Plan on doing a search for that PDF right away, thanks!
glugglug: That's true I suppose, but you still have to target a platform with C++ right? Whereas with Java you can just code it and let the JIT compiler handle platform specific stuff. Now if you don't necessarily have to target a specific platform, but instead simply compile a different package for each OS...that could be a possible solution.
hudster
809
Depending on what exactly you're doing, maybe you want to look into a product like Qt, by TrollTech. They have free versions available for non-commercial development here
Maybe it's not quite what you're looking for, but I figured I'd mention it anyway.
Aug 16, 2001
22,505
4
Kylix and Delphi is also availible in a FREE personal edition.
jpprod
2,373
Java + Swing is the way to go. Java is fully platform-independent, and the fully-featured GUI-building package Swing has been a standard part of it since v1.3.1. With Swing you can even make the GUI look almost identical on all platforms (using the default platform-independent look&feel).
Atheras
63
Thanks for all the info guys....I've decided that I'll likely go with Java + Swing as the development platform. So long as I can figure it out :)
