stupid question...
from what i can tell, cross over cables are simply cables that one end is switched.... however they are like 1/3 the price of normal cables....
so would it work if you bought it, cut one end off, then switched the wires back, and then put a new end on?
also, if you link 2 crossover cables with a connecter thing, will that be a normal cable then?
