Critique this noob's first system build!
After doing research on this site and taking a look at several of the "systems buyer's guide" stickys, I've decided on the specs for my first DIY system build.
Here they are:
Processor: AMD Athlon 64 3200+ winchester - $190
Memory: 1GB Corsair Value Select DDR PC3200 - $97
Video: evga 6800gt - $374
Mobo: DFI Lanparty UT NFORCE 3 - $103
Case: Antec Solution Series ATX Mid-Tower w/ 350W Power Supply $80
HD:Seagate 200GB 7200RPM IDE Hard Drive - $115
DVD: NEC 16x dual layer - $60
Total without monitor - $1019
Please critique my choice of motherboard and my case/psu as well as anything else
Your CPU is S939, your mobo is S754. Incompatible.
The PSU, while it'll probably still run that, might be cutting it a bit too close for comfort, but the Antec Sonata with a True380 isn't much more.
Not if you use a big enough hammer 😉
Ausm
Ausm
True 😛
Saw that case on Newegg.com for $59 today.
Antec Tower
I recommend the Chaintech-Ultra NF4 motherboard with an x800xl. If you don't plan to overclock you'd be fine with a retail winchester 3000+.
I think your PSU is fine personally.
Grab the Sonata. It currently is $96 with free shipping from Newegg. Get it before they add shipping charges back on.
As for the MB, the Epox 9NDA3J is a good budget board and still OC's well.
Like others have said, 350W is not quite enough. Otherwise, this should work OK (assuming that the processor will fit the mobo).
**Optional upgrades**
These upgrades are only if you want to spend some extra money. They are OPTIONAL.
I would get two optical drives if it were me. You could throw in a combo CD-burner and DVD reader for $30 or so. I am old-fashioned, but I would also throw in a floppy for loading drivers and BIOS upgrades.
If you like quiet, upgrading from the stock heatsink to something like an XP-120 would be nice if you have the dough.
And if you like quiet, also get a fan controller and a couple of extra fans to fit your case. Better to have four quiet fans than two loud ones.
Also, be sure that you get a SATA hard drive. Save PATA for the opticals.
And don't forget windows, fish tanks, LEDs, neon tubes, etc. 😉
I like the Sonata Case also and that is a good price.
Ausm
Originally posted by: Sandman223
Thanks for the advice guys, I'm going to switch to the Sonata with a 380watt psu.
As for the motherboard, what do you think about this one Epox 9NDA3+
Same thing as the 9NDA3J mentioned earlier, but with more features. Another good board if you go AGP.
Can anyone tell me what they would change about this so far:
Video: evga 6800gt
Mobo: Epox 9DA3+
Case: Antec Sonata w 380w psu
HD: Seagate 160GB SATA
CD/DVD: NEC DVD-R 16x
Video: evga 6800gt
Mobo: Epox 9DA3+
Nothing I'd change unless you want to have PCIe, in which case I'd get an ATI X800 XL and then find a good PCIe board.
Video: evga 6800gt
Mobo: Epox 9DA3+
if you decide to go PCIe with the x800xl, i'd pick the dfi nforce 4 ultra board. it is about $20 more than the original nforce 3 you mentioned at the top.
Make sure thats an agp 6800gt your looking at, not a pcie one.
Aside from that, it looks good. A truepower 380w should run that system well, my old truepower 330w ran the system in my sig but with a 6800gt instead of the x800xl.
If i were to go with the PCI-E, what video card would be comparable to the 6800gt as I have not seen any non-agp that are reasonably priced?
X800XL. It's slightly below the 6800GT in performance, but you can find it some places for its MSRP of $300.
Go PCI-E with the X800XL... You'll save money and get comparable performance. Stick with the 3200. Ram is great. I would go SATA on the HD just for cable maintence, and it's only like 10 bucks more.
Yup,X800XL is your best bet.
I would also like to add that it would not hurt going down to a 3000+ and pair it up with a EPoX EP-9NPA+ Ultra.
What is the differance between x800xl x800 pro? I cannot keep up with all these little changes they make to video cards. It's getting a bit ridiculous if you ask me.
I believe the pro is the faster card of the two and is also on sale ($279) for less than the cost of the xl (for today only!)
http://www.newegg.com/app/ViewProductDesc.asp?description=14-102-465&depa=1
All of the other PRO cards cost more than this xl
PRO
XL
Edit:
All the PRO Cards have 12 pixel lines and higher clock speeds than the XL
The XL has 16 pixel lines and lower clockspeeds than the PRO.
I would'nt doubt it if some of the xl cards had only 64 or 128bit memory interfaces vs. the PRO's 256bit.
