CASE-
MAXTOP Signature Series Type II Mid Tower PC, Model "CSX-147K2FGRAY" -RETAIL
31.50 with no P.S
Motherboard-
MSI "K8N Neo2 Platinum" NVIDIA nForce3 ULTRA Chipset Motherboard For AMD Socket 939 CPU -RETAIL
Specifications:
Supported CPU: Socket 939 AMD Athlon 64FX/64 processor
Chipset: nForce3 ULTRA
RAM: 4x DIMM Supports dual channel DDR266/333/400 Max 4GB
Slots: 1x AGP 4X/8X, 5x PCI
Ports: 2x PS/2, 1x COM, 1x LPT, 8x USB2.0(Rear 4), 1x IEEE1394, 2xRJ45, 1x S/PDIF Out, Audio Ports
IDE: 2x ATA 133 up to 4 Devices
SATA/RAID: 4x SATA RAID with 0,1,0+1
Onboard Audio: ALC850 8-Ch
Onboard LAN: Marvell 88E1111 1000Mbps, Realtek 8110S 1000Mbps
Onboard IEEE1394: 3x ports by VIA 6306
140.00 dollars
Video Card-
eVGA nVIDIA GeForce 6800 Video Card, 128MB GDDR, 256-bit, DVI/TV-Out, 8X AGP, Model "128-A8-N343-AX" -RETAIL
Specifications:
Chipset/Core Speed: nVIDIA GeForce 6800/325MHz
Memory/Effective Speed: 128MB DDR/700MHz
BUS: AGP 4X/8X
Ports: VGA Out(15 Pin D-Sub) + TV-Out(S-Video) + DVI
Support 3D API: DirectX 9.0c, OpenGL 1.5
Cable/Accessories: Manual, DVI to VGA Adapter, 2 Cables
I am banking on using Rivatuner to unlock the last 4 pipes.
246.00
Power Supply
Antec 480 watt 120mm fan ATX 12V v2.0 power supply, Active PFC, Model "NeoPower" - Retail
127.00
Processor-
AMD Athlon 64 3500+, 512K, L2 Cache, Socket 939 Windows Compatible 64-bit Processor - Retail
267.00
Memory-
Patriot Dual Channel Kit 184-Pin 1GB (512MBx2) DDR PC-3200, Low latency 2-3-2-5, Model PDC1G3200LLK - Retail
130.67
Hard Drive-
Maxtor DiamondMax 10 200GB 7200RPM 16M P-ATA/133 Hard Drive, Model 6B200R0, OEM Drive Only
Specifications:
Capacity: 200GB
Average Seek Time: 9.0ms
Buffer: 16MB
Rotational Speed: 7200 RPM
Interface: ATA 133
106.00
I want to try this drive with the 16mb cache
DVD-Burner-
NEC 16X Double Layer DVD±RW Drive, Beige, Model ND-3520A, OEM
Specifications:
Write Speed: 16X DVD+R, 8X DVD+RW, 4X DVD+R DL, 16X DVD-R, 6X DVD-RW, 48X CD-R, 24X CD-RW
Read Speed: 48X CD-ROM, 16X DVD-ROM
Interface: ATAPI / E-IDE
Buffer: 2MB
50.00
Comes to about 1,150 w/shipping included.
All constructive suggestions are welcome.
TIA
Ausm
31.50 with no P.S
Motherboard-
Specifications:
140.00 dollars
Video Card-
Specifications:
BUS: AGP 4X/8X
246.00
Power Supply
127.00
Processor-
267.00
Memory-
130.67
Hard Drive-
Specifications:
Capacity: 200GB
Buffer: 16MB
Interface: ATA 133
106.00
DVD-Burner-
Specifications:
Buffer: 2MB
50.00
TIA
Ausm
