So I've been burning my eyes out for the past couple of weeks refining different gaming builds I've come up with. My obsession at the moment is whether or not I will be able to run Crysis smoothly at high settings or better (because in my mind if I can then I will be able to play anything for the next few years)...
I run at 1280x1024 so SLI is not necessary. I'm upgrading from an aging AGP system and I would like to expect MONUMENTAL differences in performance plus a bit of future-proofing in order to avoid doing this again for a while (although it is fun)
Here is what I've come up with so far (I'll include everything to give an accurate total):
Pioneer DVD/CD burner - $29.99
http://www.newegg.com/Product/...x?Item=N82E16827129018
Antec 900 case - $119.99
http://www.newegg.com/Product/...x?Item=N82E16811129021
Seagate 250gb hd - $59.99
http://www.newegg.com/Product/...x?Item=N82E16822148262
XFX 8800 GTS 512mb - $249.99
http://www.newegg.com/Product/...x?Item=N82E16814150267
Corsair 650watt PSU - $109.99
http://www.newegg.com/Product/...x?Item=N82E16817139005
G.skill 4gb (2x2gb) DDR2 1066 ram (dual-channel) - $139.99
http://www.newegg.com/Product/...x?Item=N82E16820231166
Gigabyte GA-EP35C-DS3R Mobo - $144.99
http://www.newegg.com/Product/...x?Item=N82E16813128082
Intel Core 2 Quad Q6600 - $214.99
http://www.newegg.com/Product/...x?Item=N82E16819115017
Windows Vista Home Premium 64bit (OEM) - $94.99
http://www.newegg.com/Product/...x?Item=N82E16832116204
Total so far w/shipping and taxes to Cali is $1,297.34.
I'm looking for best bang for the buck but at the same time would like to be set for the next couple of years as well as be able to upgrade. If I need to spend a little more to get something a bit better, I will, no problem.
Thanks a lot
Thanks a lot
