Crisis System Req
EvanAdams
844
By a forum admin though: Linky
Minimum Requirements
CPU: Athlon 64 3000+/Intel 2.8ghz
Graphics: Nvidia 6600/X800GTO (SM 2.0)
RAM: 768Mb/1Gb on Windows Vista
HDD: 6GB
Internet: 256k+
Optical Drive: DVD
Software: DX9.0c with Windows XP
Recommended Requirements
CPU: Dual-core CPU (Athlon X2/Pentium D)
Graphics: Nvidia 7800GTX/ATI X1800XT (SM 3.0) or DX10 equivalent
RAM: 1.5Gb
HDD: 6GB
Internet: 512k+ (128k+ upstream)
Optical Drive: DVD
Software: DX10 with Windows Vista
I have to say why I LIKE stuff like this. If clearly falicies are spread and begin to be accepted the publisher / creator will have to make some statement as to truthfullness which will, hopefully, have some bit of truthyness in it somewhere and maybie a detail or two.
Polish3d
5,500
Is it still planned to come out in 2006? I want this hot bi%ch as soon as possible
m21s
775
First I've heard of this.
I wonder if it's true?
shabby
45
Its speculation, so no its not true. But since this fud is spreading to every forum people think it is.
EvanAdams
844
That is my point. If it spreads the people making Crisis will have to say something of substance.
Anyway dont we all think that a PhysX card would be in the recomended setup? I do.
m21s
775
It was already stated by the developer that it will not support a physX card.
I do remember hearing that in one of the interviews.
warup89
61
i hate that ppl are so rushed to meet these qeuiremenst like crisys is a super game i means its only a shoting game with a littlw more eye candy, dam!
m21s
775
Not much of a gamer huh :)
Sunrise089
882
Did you play FarCry? I'm guessing you didn't.
DeathReborn
2,786
789
Shader Model 2, bit low if you ask me. I'd put it as a SM3/4 only title myself as it won't look that great on SM2 hardware.
Ichigo
2,158
Oh really? How does SM2 detract from the experience to the point of unplayability?
Second, PhysX card by Ageia sucks.
Third, if it's a good game it's a good game, and if the gameplay is great then the amazing graphics only make it that much better.
Munky
9,372
Well, looks like I fall above the recommended requirements category, maybe I wont even have to buy a DX10 video card for Crysis. Well, except for Vista. But why would SM3 (DX9) require Vista?
450R
319
Where'd you get the idea Vista is required? Minimum is DX9/XP, recommended is DX10/Vista.
SpeedZealot369
2,778
I don't understand why people get so excited about games using the 2nd core of the cpu. The frames wouldn't increase much would they? It would just balance the load between both cores that's all (if I'm assuming correctly)
It just bothers me how people go berserk when they hear that a game will use duel core cpu's..
thilanliyan
12,085
2,281
Actually I think Quake4 gained a noticeable increase in performance when the dualcore patch was used. I think...don't quote me on it.
SpeedZealot369
2,778
I just think alot of people would buy a "duel core" game regardless of wether they like it or think it's a good game, but just because it will use both cores they'll buy it.
Anyone know what I mean?
Polish3d
5,500
No. F- that. I think physics will be calc. on the CPU
Munky
9,372
Minimum is SM2/XP
Recommended is SM3/Vista
I was talking about how I have the recommended HW, but if Vista is required just to have SM3 effects enabled, that's kinda shady.
Praxis1452
2,197
the cpu really isn't good at calculating physics. It isn't parallel enough at all. The gpu is better but a efficiently designed ppu is much much better. However until physics is implemented properly with pci-e and games physics is kinda useless. maybe eventually everything will merge into one die but as of now it's much easier to produce seperate devices.
