- Oct 9, 1999
- 488
- 0
- 0
well since i'm having some weird network problems.. i'm wondering if my cabling is correct..
looking at the gold pins of the plug from left to right.
orangewhite/orange/greenwhite/blue/bluewhite/green/brownwhite/brown
my problem with my network is that with 2 computers connected to the switch.. the lights come up.. and they blink.. but the computer will say the cable is connected/disconnected and will go back n fourth randomly.. it'll be fine for a while then go nuts and then settle down again.. nics are installed correctly and i assume the switch is working.. at least the last time i used it it was.. everything lights up okay.. so i'm really confused..
i'm going to a friends house tomorrow to test the switch and cabling.. the cable could be bad in the middle eh? which would not allow for proper communication between the two computers...?? which could be causing all my networking whoes??? right or is it something else???
BTW the nics i'm using are intel 8255x 10/100 dunno if these are problematic or what but i thought it'd be helpful to include..
