cricket mms not working. help pls
Make sure you setup all three entries listed on that page that are MMS related, save, back one screen, and select the new APN that you just set. Then restart the phone just to be absolutely sure (double check if the APN didn't change back). Try again.
thanks! restarted. apn still has cricket settings that i created. still no mms though
For the MMS proxy, use proxy.mobile.att.net.
A Reddit search for Cricket MMS issue will probably find you the post where I found this information. Apparently, the proxy points to a private address which doesn't allow MMS to travel when you are on WiFi. If you are on cellular, the MMS will send perfectly. That's why you may notice that the MMS will come in if you toggle WiFi/Airplane mode/restart your phone.
This may sound silly, but make sure there are no spaces after the commas for each apn type. My keyboard auto spaced after each comma. Drove me crazy until I noticed it.
i just tried this. mms refuses to work after reboot
here's my screenshot
https://drive.google.com/open?id=0B4HIP0cWoO5LNld3ZHdsbDBKUW8
