Creative Sound Blaster Audigy/Live! Drive Ribbon cable
ComputerWizKid
1,188
I have two Creative Sound Blaster cards one is a Live! 5.1 and the other is an Audigy Platinum I have the 5.25" interface bay for the Audigy but I lost the cable.Can I make an old IDE cable work with it? both have 40 Pins but the key pins are in different places. If not how can I make my own cable?
Here is an image of the Creative AUD_EXT connector on the Sound Blaster Live! 5.1
both cards have the same connector
Thanks
Doomer
3,721
I would think so as long as there are cross overs in the original cable.
TerryMathews
I used a 40 pin IDE cable (40 conductor, not 80) without issue on my Audigy for years.
Just make sure you're aligning pin 1 correctly on both units.
