Creative Nomad Jukebox Zen keeps freezing! (Solved)
Status
Not open for further replies.
xagent
sent this in to their tech support. Anyone experiencing similar problems/know how to fix it?
Problem Description:
After trying to load my files onto the Jukebox Zen, I
suddenly got a message saying the nomad is not responding or
is busy, and only about 500 of the 3,500 files had been
transferred. So I reboot the PC, delete what had been
transferred, and do it again. Now I see it transferring
quite a bit, as it went all the way up to the "T" files
(alphabetical order. I stopped watching the progress after
that. When I came back, I assumed it was done. But in
Playcenter, it only showed some 1,500 files had been
transferred. I double checked the Zen, and only the files up
to "L" had been transferred. Then when I tried to delete the
playlist again from Playcenter, it said the Zen was not
responding or busy. When I tried to delete it from within
the hardware, a box popped up, simly saying "Error". So I
pressed the reset button, and it re-built the library. Then
when I tried to access the playlist, it said "Error" again.
I pressed reset again, but this time it kept freezing at
the "Re-Building Library" stage. It keeps freezing towards
the end, right below the "..." text. I have let it sit for a
while, it still did not work. I tried to do it while it was
plugged into the DC adapter, but it still would not work. It
simply gets frozen at the screen, and I can't even turn it
off. Only the reset button works, but that just starts to re-
build the library, until it gets frozen again. My computer
doesn't detect it when pluged into my Firewire or USB port.
Error Messages Received:
first it said "Error" when I tried to access the playlist.
Now it just gets frozen everytime at a particular point in
the "Re-building Library..." stage.
Troubleshooting Steps Performed Thus Far:
I've tried resetting it several times, I've tried letting it
Re-build the library while plugged in, and this still did
not fix the problem. I've let it sit for a while but
resetting it then still does not work. I've also posted
about the problem on a few message boards but have not found
any similar problems or solutions.
do you have the latest drivers/software? from their site:
Creative_FileManager_1_01_06.exe
Revision: CFM-WEB-4-US
Date: 12/18/2002 Size: 3.8 MB
This is the latest release of the Creative File Manager (English only) and is meant for users running Windows 98SE, Windows Millennium, Windows 2000 or Windows XP.
This release contains the following:
*Creative File Manager 1.01.06
*Drivers v1.08.02 (non-WHQL certified) for NOMAD Jukebox 2, NOMAD Jukebox 3, NOMAD Zen, NOMAD Zen (USB 2.0)
Hey everyone, thanks for the help. I have been working on it here and there since I posted my original post. I have got it working thank you for the help.
So glad you made a new account to update us on your Creative Nomad, and gave us a status update 14 years later. 😉 Holy necro thread, batman.
14 year old necro post just to say it was solved? And OP changed name.
Status
