Creative Labs 8x4x32 & Firmware help
Comp625
1,216
Greetings,
I wanted to install CloneCD today but before I insatlled, I checked their list of Supported Writers. Now my CD-RW Drive is listed there but for Firmware Revision, it says the Firmware has to be equal or greater than v1.07.
CloneCD Supported Writers Page
That's fine and dandy so I mind as well go update my firmware. When I go to choose my burner through Creative's list, it says they don't have any firmware updates (or anything else) for my burner in WindowsXP. HOWEVER for WinME, 98SE, etc...Creative lists the firmware upgrade that I need (v1.09) to get my burner to work properly with CloneCD.
No WinXP support ???
WinME/98 is supported
My question is, will the 1.09 firmware still work with WinXP? If not, would CloneCD burn cds PROPERLY without the 1.07+ firmware revision? Thanks in advance!
ChurchOfSubgenius
2,310
I would go for it, just because it's not supported doesn't mean it won't work, plus, if it won't function properly you can always flash it back.
