Creative CD-RW and Nero Burner Problem...
ogcaldwell
I have this Creative CD-RW that has been used with Nero Burner very well, but has recently begun to act funny. It will usually only burn right after I have rebooted the system. If after I burn something, I shut the program down or it crashes, it will not restart or if it does, it will not burn. I am not sure if this could be tied into the Win98 ASPI layer and if extracting it from the win98 cd could help. Since I have never performed this operation, I am not sure what to expect once finished. I have a step by step on how to do it though.
Well, the system has a 400Mhz processor and 64Mb of RAM. What do ya'll suggest.
Willoughbyva
3,267
Try reinstalling Nero or dl an updated one if you qualify for it. Also try newer chipset driver and such.
Will
wefixitalways
37
I can tell you from experience, it is the Creative Labs hardware. I bought my first Creative with Nero burning software. The Creative CD-Rom was a 8x4x32 and it lasted only about 6 months. And I did not use it very much. Creative sent me a replacement drive and it lasted 3 or 4 months. It started acting up like you were describing and then stopped working all together. Needless to say I will never buy another Creative product.:disgust:
Muse
41,372
10,484
<< I can tell you from experience, it is the Creative Labs hardware. I bought my first Creative with Nero burning software. The Creative CD-Rom was a 8x4x32 and it lasted only about 6 months. And I did not use it very much. Creative sent me a replacement drive and it lasted 3 or 4 months. It started acting up like you were describing and then stopped working all together. Needless to say I will never buy another Creative product.:disgust: >>
It might be the drive, maybe not. I have the 8x4x32 Creative too, and I don't think there's anything _wrong_ with mine other than it won't write in CD Text (although Nero supports it) and it's noisy as Hell. Sure glad I got a Liteon 24x. The easiest thing to try is uninstalling and then reinstalling Nero. Might not hurt to remove the drive and reinstall it, so Win98 gets a fresh take on it. Just a thought. Harder to reinstall your Win98, or preferably, Win2000, but there's got to be an advantage in installing a fresh OS, especially if it's been a while since you installed Win98. Don't know about the ASPI layer stuff.
