Creating a Water Cooling System
StevieMo
Hi all. This is my first post. Hope you all can help.
I am fed up with the noise of my CPU fan so want to build a water cooling system.
I only want to cool my CPU to start off with.. then chipset, HD and Graphics Card.
First off all could you recommend a case that would fit in say 2x 120mm fans and is tall enough for the water cooling equipment.
I want to custom build the water system with the best parts available. (Price/Performance)
What do i need and what are the best?
Thanks in advance for any replies.
Cheers!
Stephen
this case
you can fit a bix at back where 120 mm fan is , or remove hard drive cage to place a dtek heater core in it
for pump consider mcp650 12 volt at swiftnet or buy from dangerden . both same pump
for waterblock consider the TDX , some will suggest the MCW6002 swiftnet block as well
some 1/2 inch line will be needed then that should work well
Jen
