I'll try to make this as condensed as I can.
With the original setup, everything worked fine.
What has changed:
Installed a Thinkpad T43 (temp. till an R31 gets here) to run pfsense (router/firewall on FreeBSD) behind an Actiontech Router (from FiOS install and I have to keep this because of the coax interface) with the DMZ set to the wan NIC of the Thinkpad.
I also moved a Dell Powerconnect 2016 16 port 10/100 switch that had been use on the 2nd floor down to the basement where it connects to the LAN nic of the thinkpad for distribution.
Everything is working great, the traffic shaping is super, ports all nice and forwarded to the server. Internet is running at normal speed, and so are transfers across the LAN....
Except for one machine, the HTPC. It connects and I can ping stuff on the lan and internet as well as resolve names, but the actual data connectivity is so slow that it can't even load webpages. I can't connect to any other machines either...its like data traffic is just not happening.
So far i've installed a different NIC and i get the same result. I've plugged that cable into my other Thinkpad and i could rock 11MB/s no problem. I plugged the cable back into the actiontech and it would work without any issue.
Its like some weird problem between 7 and that switch. I'm going to try plugging in another switch into that switch and run the box through it to see if it makes any difference.
But for the time being, any ideas?
What has changed:
