Phoenix86
- May 21, 2003
- 14,644
- 10
- 81
dat thrust
Bricks are aerodynamic enough with proper thrust. :awe:
dat thrust
Meh, not so crazy. Pretty sure military cargo planes pull similar maneuvers all the time so as to make harder targets for ground fire.
789 is somewhere around 300,000 lbs operating empty weight. i'm assuming they didn't load it up with fuel for doing demonstration flights, so i'm going to ignore that. thrust is about 150,000 lbs. that's a thrust to weight ratio of about 1:2. the empty weight of an F-86 sabre is about 11,000 lbs (operating empty weight is empty weight ++, so you can fudge that upward some). thrust was about 6,000 lbs. so, the 789 isn't far off the thrust to weight ratio of a korean war fighter plane.
