Recently I noticed that my core temps with my q6600, cooled with a thermalright Big Typhoon, were way higher than seems normal, or safe. Running prime95 (on all 4 cores) results in temps just under 80C after a few minutes, and idle temps are in the mid to high 40s (as reported by Speedfan). I haven't tweaked the stock settings in any way, and the fan on the typhoon seems to be fine, and spins at about 1200 rpm, according to speedfan. I thought that maybe I had installed the cpu fan kittywompus or something, so I pulled it off, cleaned off the thermal grease, reapplied it, reseated the fan, and there seems to be no change in the temps. The case has three 120mm fans, all of which seem to be operating normally. In general, the machine feels kinda sluggish, and occasionally reboots spontaneously (maybe it overheats and auto-restarts?)
Any thoughts for things to look at or try? thanks...
cpu: Q6600,
mobo: ABIT IP35-E
fan: thermalright big typhoon,
ram: 2gb
case: coolermaster (something big, I forget the model name)
cpu: Q6600,
mobo: ABIT IP35-E
ram: 2gb
