Originally posted by: mechBgon
Troubleshooting starter
- Overview of the problem
Computer is randomly freeze/crashing, particular during games
- Full description of the problem and symptoms
When i am playing games, sometimes i get a random crash. The crash is like the game freezes, the sound starts repeating really fast, almost like a buzz. The only thing to do is hit the reset button. Once i hit reset, the post code indicates a video error, (ami bios, 1 long 2 short). But if i power off, then power on the post screen comes up and says "The previous performance of overclocking is failed" (even though i was not overclocking!!!) I then hit space bar to go into bios, save bios and exit, and everthing is fine.
This is generally during games, it started with far cry 2, i thought it may have been an issue with the game, but then it showed up in crysis warhead, the witcher, and most recently arkham asylum among others. In arkham it seems to happen at the end of the combo when it goes into slow motion knocking down the last bad guy. But other than that i havn't found any patterns.
it would also happen whenever i tried to update the same game with the ingame windows live update.
- Did it work normally at one time, or has the problem always existed?
this seems to have appeared after i changed processors, but ... read on
- Is the problem consistent and repeatable, or entirely random, or semi-random?
see above
- I already tried these steps:
I am fairly confident it is not overheating, all system temps remain stable and system is well cooled.
I have stress tessed the cpu with 4 windows of cpu burn in, for around a day long, with no issues, also stress tested with prime 95 for a long (approx 20 hours ) period with no issues and good heat dissipation, so it makes me wonder if it is the cpu?
I have stress tested the video card with ati tool, video card stress test, furmark ozone3d, and 3dmark 06 with no issues. furmark raised the temp way higher than any game has and nothing wrong.
I updated motherboard bios thinking maybe it was an issue that had to be straightened out with the chipset, but no difference. (before i update i had ami v1.8, and instead of 1 long 2 short, it was 8 short beeps, but both are video card related)
all drivers are up to date..
tested memory for 20 + hours with memtest 86+ and windows memory diagnostic, both reported no errors.
- My software:
- windows xp, 5.1 with service pack 3
- antivirus and firewall are comodo internet security
- Firewall
- Feel free to add more software details that you think might be relevant to the issue
- My hardware
- System brand & model, if it?s a pre-built system such as a Dell, HP, Gateway, etc. If it?s not, fill in as much of the information below as you can.
- Motherboard brand & model- MSI k9a2 neo-r
- CPU model (and is it overclocked?)- amd x4 940 be (at stock)
- Video card(s) evga 8800 gt, 512mb
- RAM modules brand & model patriot ddr2 800, 2x 2048
- Power supply brand & model silverstone st50ef plus 500 watt
- Feel free to add more hardware details that you think might be relevant to the issue- also have sound blaster audigy 2 zs....
- Other information that might be relevant
(any other information that might be related to the problem)
i can provide any more info you might think of...
So i just wanted to hear some opinions before i get in there and swap processors again, it did start when i changed to the 940, from 5000 be, but as i said earlier the cpu was stable in tests, and good temps, plus the bios beeps for video made me wonder, so i just want some second opinions, thanks.
