wkelly1368
System:
Chaintech VNF 4 Ultra Mobo
AMD Athlon 64 3000 Venice
SAPPHIRE 588L Radeon X600PRO 128MB DDR PCI Express x16 Video Card
CORSAIR ValueSelect 1GB (2 x 512MB) 184-Pin DDR SDRAM DDR 400 (PC 3200) Dual Channel Kit System Memory - Retail
Western Digital Caviar SE WD1600JD 160GB 7200 RPM Serial ATA150😕 Hard Drive
Western Digital Caviar SE WD800JB 80GB 7200 RPM IDE Ultra ATA100 Hard Drive
Windows XP SP2
ASUS Beige IDE DVD-ROM Drive Model DVD-E616P1
NEC DVD Burner Beige IDE Model ND-3500A
The 2 DVD ROMs are just under 2 years old
The 80GB HD is about 3 yo (2nd HD)
Everrything else is about 14 months old.
For the last week or two I have noticed the system rebooting on its own with the resulting box to notify Microsoft of a severe event.
Yesterday it crashed big time. When I tried to reboot all I got was a continuous beep from the unit.
After letting the unit sit for awhile I wass ableto restart but the BIOS page said NTLDR was missing. I found that the BOOT order for the HD's and CDrom's were changed. I reset them and Windows was able to restart.
At the BIOS page before Windows loads I was getting the following POST Codes: 52,65, 75 and 7F. I think they are probably important, I checked the Chaintech webpage but I could find nothing about this. I sent them a support request but the automated reply said they are backed up. That doesn't sound too promising.
When I was able to restart Windows yesterday, I tried to run Check disk on C. The system rebooted before finishing. I did run chkdsk from the Windows repair area after restarting with the XP disk in. It said the disk was fine.
As of late last night and this morning, all I get is the continuous beep and nothing else.
I hope that wasn't too long winded and confusing. Any ideas where I go from here?
Thank You in advance.
Windows XP SP2
