My System:
AMD Duron 1.0Ghz CPU
ECS K7S5A Motherboard
512MB DDR PC2100 Ram
Soundblaster Live 5.1 MP3+
Yesterday I decided to spend $130 on a new video card. My choice was a PNY Geforce 4 TI 4200 (64mb ddr version)
I plugged it in, installed drivers, ran a game. Everything seemed ok. All the sudden my computer went boom and after hours of troubleshooting I found out my power supply was only 235 watts trying to run my system with the new card. I got a 300watt power supply, all is ok now.
However I'm getting really bad frame rates in most of my games. Especially UT2K3.
Running the benchmark I was consistently getting the following (give or take a tenth) in any resolution...
flyby 77.36
botmatch 24.69
that was in 1024x768, 800x600, and 640x480. I tried setting it to opengl and got the same results. I even overclocked my card from 250/500 to 270/540 and there was no increase in fps.
I ran 3dmark and got 5990 marks which is halfway decent from what I heard. A friend who has a geforce 2 mx 400 gets 2901 marks but he gets 35fps in ut2k3.
I ran Battlefield 1942, and I don't know the command to show fps but it seems pretty laggy... I ran Army Operations and the fps is around 20, and I ran UT2K3 (single player and multi) and I get around 20fps, average around 17.
Vsync is disabled. Anistropic filtering is off. Antialiasing is off.
The fps stays the same even if I enable vsync and those other options...
I began with the 30.82 drivers, and am now using the 40.41 drivers.
What else can I try? I'm about to return this card b/c my Geforce2 GTS 32mb ddr card ran similar. Have you heard of anything like this?
Thanks for any replies.
Duritz
flyby 77.36
botmatch 24.69
Duritz
