Originally posted by: SKC
ndee-- it's possible that the wire got jostled loose from the contact from pumping too much from the tweeter. Hopefully this is this case, and you can just sauder it back on. Good luck.
yeah, I hope so too
Originally posted by: Eli
blew a fuse, lol.. that's a good one.
Yeah, but I was under the impression that his symptoms would be different if the fuse was blown.Originally posted by: Pepsi90919
i don't see how it's funny...you've never heard of breakers on speakers before?
Originally posted by: Klixxer
Originally posted by: zephyrprime
Better speakers have fuses and entirely reasonable to put one on for situations just like this. The sub on my altec lansing PC speakers has a fuse. Also, some speaker's I've built have fuses.Originally posted by: Narse
Sounds like you blew the tweeter in one of them. BTW speakers don't have fuses.
You should be able to fix your speakers with a new tweeter. The sound will be mismatched buy with cheaper speakers, you may not notice too much anyway. On second thought, unless you know what you're doing, you should just get new speakers.
Altec Lansing is "better speakers"? LOL, no.
the rest of your post? eh buy with cheaper speakers?
Cerwin Wega is ok for home use, it's a step below the REALLY expensive speakers that none of you have and most of your somewhat more expensive speakers are usually not as good.
He blew the tweeter, i would replace both tweeters with same spec tweeters (that is, not only the spec, the same reference too. (as in, they are mounted in similar speakers)
