crap on cpu, how to clean?
Use acetone to melt and remove the thermal pad, then use a pencil eraser to simply "erase" anything left behind...
alcohol...or goo gone. Sometimes alcohol just doesn't cut it, especially with those putty-like pads.
Regular drugstore Isopropyl Alcohol is not pure and leaves a residue. Audio Tape head cleaner is better.
Now that Radio Shack has discontinued the Foam Swabs, now what the heck can I use that leaves no residue? Don't tell me Q-tips, they leave lint.
Originally posted by: CheapArse
so these cheapy ones from saveon with only 70% wont work?
they will work, but they leave residue. i have some 97% swabs. but to remove the residue, you'll want something better.
better than 97%? or your 97% swabs work? and will they sell those at rite aid?
Originally posted by: Cerb
Originally posted by: hypersonic5
I scaped my thermal pad off my HS with a razor blade...
You might want to use a solvent in addition to that...
Too late. I'm ghetto like that. Plus, the faster I kill this comp, the faster my parents give me the $$$ to upgrade.
Well, in that case, kill away!
