Well it was a hard find but it looks like you just bought a piece of crap...enjoy ..
Product Reviews Review This Product
Overall Rating: 2 out of 5 2 5
Poor Lighting vs Drop Light, May 27, 2009
By Anonymous Reviewer from Fremont, California
"18 gauge 15 ft cord with a bulky 12v dc 400ma transformer.Narrow light spot area. Lighting is much poor than a 25w drop light. The switch is hard to on/off.
It can work in small space like between the fire wall and the engine but drop light can't.
Will look for another alternation."
Was this review helpful to you? Yes No (Report Inappropriate Review)
Overall Rating: 1 out of 5 1 5
Junk light, April 2, 2009
By Hokietwo from Virginia
"It's junk!!!! You have to light a match to see if it's working. I would return it except it would cost more than tossing on the dump."
Overall Rating: 3 out of 5 3 5
Rugged but has inefficient transformer, March 5, 2009
By HailStone from Sunnyvale, CA
"So far it's held up to abuse much better than so-called "Rough Duty" incandescent drop lights. 3x20 LED series/parallel design should degrade gracefully even with a few future LED failures.
Spot light is brighter than a 160 watt fluorescent fixture at the same distance, but only within the LEDs' narrow 15 degree beam width. Cord is heavy duty but not very flexible when cold.
Transformer draws 9.1 watts when on and 3.7 watts when switched "off". This "vampower" would cost $7 per year here in CA if left plugged in when off. It also wastes about half the power drawn when on -- definitely not an energy star like most other LED lights."
1 of 1 people found this review helpful.
No go in my garage, January 16, 2009
By NoDuck from Winston Salem, NC
"I was excited to receive this light as a gift only to be disappointed when I went to use it. The power switch is ridiculously hard to operate. The light pattern is not very bright and it is hard to turn the light just right to illuminate the work area."
