I understand how tile walls naturally crack at changes in plane in our shitty American wood framed buildings due to soil movement and framing expansion/contraction due to seasonal/temperature changes. For a full tile shower one can caulk the corners between the walls and floor, as any moisture which gets through the wall grout can travel down and below the floor to the secondary drain inlet.
How does one deal with this with tile walls above a bathtub? Grout between the walls and tub cracks, but caulk will not allow trapped moisture to escape. Is there a flexible material to use for this purpose that won't crack but is permeable to allow moisture to escape the wall?
