CPU-Z v1.74 - MultiThread CPU Benchmark
Bubbleawsome
4,834
1,204
3.6Ghz 4670k because it won't overclock for crap. I need to buy more chips until I get one that OCs well, but money.
YBS1
1,945
129
Daily 4.6GHz - It's still only turbo'ing up to 4.2GHz for the single threaded portion of this bench, don't know what that's about.
LTC8K6
28,520
1,576
A 55 watt laptop CPU vs a 95 watt Skylake desktop CPU? STILL holding it's own = WORTH IT for 3+ yrs & counting!
A $1K laptop CPU is never worth it. :biggrin:
Unless you are the government. :cool:
Lorne
873
AMD 1100T 3.2Ghz, 2.6Ghz HTL, DDR2 1066 Memory.
743 ST No Turbo.
3506 MT
Thubans Turbo mode is shady at best, If it detects activity on any other cores it wont go turbo, CPUz will not let me change the affinity to one core, But if I set the affinity to a single core for WinRAR bench I can get it to hold 3.7Ghz more consistanly.
But this is also on a AM2+ MB if it make any difference.
DrMrLordX
23,147
13,240
AM2+ gives you DDR2 which isn't much of a benefit anymore. DDR2-1066 was actually pretty good compared to . . . DDR3-1333 CL9+, but you can run DDR3-1600 CL7 pretty easily (or CL6 with some effort) making the DDR2 option look pretty bad in comparison.
Regardless, Stars chips seem to struggle with this benchmark.
Burpo
4,223
473
Are you kidding me? Serious Laptop Gamers would disagree with you.. It has been the sh*t for 3+ yrs. now..
guskline
5,338
476
My 5960x below at 4.4Ghz
I run this 24/7 at these specs.
single thread=2008
multi thread=17056
SPBHM
5,074
433
3.06 Northwood in an old Dell.
Single 155
Multi 100
do you have HT active?
because I tried on a Pentium II 400 (single core) and it got 0 for MT (33 for ST), but when I used "stress" it gets around 30 something for MT while it's running, so I think it's a bug with single core CPUs, but if yours had HT it might explain it getting a score, or it's something else.
LTC8K6
28,520
1,576
Yes, HT is active.
It could be the fact that it is 32 bit. 32bit CPU-Z bench seems to run slow.
Or it could be the fact that the early versions of HT sometimes hindered rather than helped.
And the Northwood 3.06 is Intel's first HT desktop CPU.
fourdegrees11
441
@73c full load. Seams pretty stable so far.
edit: had to bump voltage to 1.258
Dresdenboy
1,730
554
citavia.blog.de
Might be kind of a timeout with not finishing a single loop during MT.
