- Feb 11, 2001
- 6,415
- 1
- 0
I have an AMD classic/slot 650 (no overclock) & been having what seems to be an overheating?/"Freeze" problem . The voltage is/was set at 1.6 which to the touch , the cpu felt a bit hot .
Also I'm updated on MB Bios & Drivers & have a decent slotA HSF .
So my question is: How much can you drop the voltage to the cpu and would it make a difference in how hot the cpu will get ?
I Have it set right now at 1.45 & it seems to be running cooler , I don't know .
I've checked the Temp. in the Bios & it ranges from 38-43C
Note: It is not the Videocard , for it does the same "FREEZE" with the Diamond Viperv550 pci , ATI AIW 128 agp & STB Velocity 4400 agp . (all with the latest drivers)
Anyone have any ideas ?
