Cpu Usage High During Games....Help!!
HarryHood85
13
Ok I have never had this problem on my computer before but it has just started showing up after christmas break when i got back to school. My computer has been turned off the whole time so I don't know what could have changed. I have a 2.6ghz HT P4 in a gigabyte 8knxp an ati radeon 9500 with the newest bios, chipset drivers, graphics drivers etc. When I play a game like prince of persia if i ctrl+alt+del the task manager shows the pop.exe is using 53% of the cpu constantly even if the window is minimized. If I understand correctly because prince of persia dosn't use hyperthreading this is about eqivilent to 100% cpu usage. This also happens in diablo 2 but the cpu usage goes down if the window is minimized. With diablo 2 i tried setting the affinity option in task manager to only use cpu0 with this game and when i checked cpu0 was pegged at 100% during gameplay. This might not be a problem for some peoples computers but i am using the stock heatsink and the crappy thremal pad ( i know i know i am going to put some as3 on it and improve case cooling) and my cpu starts to get up to 60c because of the load. I know these games never used this much cpu before so whats up? I have defraged, scanned for adware,spyware,virsus and have come up with nothing. I am sure that the games are the programs resposible for the cpu usage cause i have checked it in task manager.
Thanks for your help.
More comp info:
2.6ghz HT P4 800mhz Fsb
Gigabyte Ga-8knxp bios f9
Sblive
ati 9500 pro cat 3.10
512 mb Kingston hyperx pc 3500
120 gb wd1200jb
liteon dvd and cdrw drives
scorpmatt
7,040
97
running your cpu at 60c isnt going to hurt it that much, p4's have technology in them that if they get to hot they'll shut down. check your page filing, and make sure no one turned on the computer or opened the case.
