Hello,
need help on a CPU upgrade issue.
installed my new 4800+ X2 in my rig (Specs: A8nSLI Deluxe w/ the latest 1014 bios, 2 GB Corsair VS, 2 X 7800 GTX, WinXP PRO installed in 2 X Raptors Raid0, PCP&C 510W SLI, and my rig has never been O/Ced).
system booted fine (went to bios to check temp 36C CPU 30C mobo) but it took forever to load windows. and when the OS finally loaded,
the system was unusable because the CPU load was 100%. this went on for several minutes. finally rebooted, again same result.
took out the 4800+X2 and reinstalled my old FX-55, booted up and the system again had problems loading the OS.
thinking that my raid0 got corrupted, i installed the 4800+X2 again and swapped the raptors w/ a WD se. and did a fresh install of WinXP pro. but after waiting for 3 hours, it still hadn't completed. actually it was not even close to being done.
???? i'm stumped. i don't think the problem is the 2 CPU's or my OS, could it be that the MOBO got damaged during the install? i've been assembling computers since 96 and this is the first time i've ever had this kind of problem.
thanks for reading and any help would be appreciated.
