I have a Palimino XP1800+. I know that the new Tbred cores are better, but I got that chip...well I guess it was a year ago now. Anyway, I got my Epox 8RDA and decided it was time to start overclocking. I got a CPU unlocking kit but I had no luck unlocking my cpu. But it is such a pain to disassemble the thing because I have an Alpha 8045 heatsink. So i decided to just overclock using my FSB. Anyhow, I started working my way up and found that I could run at 1702Mhz @ 148Mhz FSB. I did several tests. I ram Prime95 for 24hours then ran this other test, i think it is just called CPU Stress Test. It is one that lets you make a stability certificate after you run it for 24hours. Anyhow, I was happily running along at my 1702Mhz. Then, the other day, my new video card arrived (my last one died and I was overclocking to keep myself busy before I could play games again). So I put my new Radeon9500 in and started up 3dmark. The system barely made it through the first test before it restarted or locked. So I turned the CPU down to stock to make sure it wasnt my card and everything was fine. Why would 3dmark make my O/C cpu have probs when prime95 and the like dont? I guess I could try more voltage. Any ideas?
thanks,
-doug
thanks,
-doug
