CPU temps seem a bit too low
covert24
Well i just recieved all of my parts for my brand new build and everything has come together beautifully. HEres a list of what i bought:
GIGABYTE GA-M57SLI-S4
AMD Athlon 64 X2 4000+ Brisbane
G.SKILL 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800
COOLER MASTER RR-CCH-L9U1-GP 92mm Hyper TX2 CPU Cooler
Its not really a problem but a concern. My temps in speedfan seema bit too low than what they should actually be. Here is a list of my temps:
Temp1- 26* (Normal)
Temp2- -18* (Messed up)
Temp3- 16* (Too low)
HD0- 56* (Normal)
Core- 6* (too low)
the core and temp3 temps are what im mostly concerned about. the temp2 i think is messed up because theres not a censor there but im not sure. let me know what you guys think
Hey,
I have an Asus P5K Deluxe with E6750 ,stock cooling. With stock cooling my MB ~ 30 and CPU ~6
I've updated the BIOS but that had no effect. Let me know if come right, I'd like to know whats going on too.
Cheers.
Try using different software, like ntune, cpu rightmark etc? I think temps are off by 15c due to some kind of bug thingy, that has something to do with the tjunction. Really can't explain it well, I remember something like that though, and I think that's it. Google it and you should find out more regarding that issue.
