CPU temps on DS3... TO High?
boles
any way to view temps on gigabyte DS3 ? mbm5 wont work from some things i have read and that is my choice app. Please help
EDIT:
Downloaded intel TAT cranked it up to 100% core usage and got temps 60-65 per core. Is this to hot ?
Easy tune says total feq is: 2640 and
cpu fsb: 330
cup volts: 1.23
rat: 8.0
mem freq: 825
mem volt: 1.90
TAT is pretty accurate on the DS3. 60c is about as hot as you want to go for a load temp but 65c is not unheard of and should probably work fine. You might want to look into a better heatsink/fan(I'm assuming you are using the stock Intel one).
i run at 41-3 idle, 50 at load on a E6400, using a non stock heatsink. I think most heat produced comes from the GFX card . 88gts. that thing cooks.
65C Core Temp is not hot. If it were the regular CPU temperature (measured on the outside), I would say it is on the high side.
