- Oct 29, 2004
- 5,594
- 0
- 0
I'm running folding@home on my P4 w/HT on both "processors" so I have 100% cpu utilization. Problem is, while my case temps have been relatively stagnant with no change in airflow, the temps keep moving from 59*C to 61*C and back and forth... I have an IC7-G so the temp readings are a bit high but consistant.. I don't understand exactly how a CPU temp can increase from 59*C to 61*C and then drop back down if it's at 100% utilization and there aren't any noticeable programs taking up that usage.
The temps should be at their highest when they're at 59* since I'm running a gromacs core which uses SSE and a tinker on the "other processor" but magically the temps rise for a while then drop and I'm not quite sure why. It's getting really annoying because at 61*C the machine is considerably louder than at 59*C and I want to figure out why it's doing this, I even closed my antivirus but it did nothing..
