I have my new a64 3000+ @ 2ghz(since i just got it) When i run motherboard monitor the case temp is higher than the cpu temp when idling. ie. cpu 35 case 41.
How is this possible? where is the 'case' sensor.. is it the sensor that came with the powersupply ro is it on the montherboard?
mobo, msi k8t neo 2-fir(k8t800pro chipset) updated to latest bios.
under load, the 'case' temp doesnt really raise much but the cpu temp does, which is how it should be
