CPU Temp rise after bios flash
imported_whatever
2,019
the actual temp did not change, the monitoring of it did. the temp sensors in computers are not good for much other than relative temperature.
orion446
114
I am using the Zalman CNPS7000 ALCU and was thinking about getting the Thermalright XP120 to bring the temps down before starting to OC
Tiamat
14,068
your temps may not improve since the zalman already is pretty good. The most that will happen is that your system temp goes down because of the 120mm fan of the XP120. However, your cpu might drop 3-4C max. What kinda thermal goo you using btw? Also is dust a problem?
