Alright well, I just upgraded my video card and motherboard. (6800gt => 8800gtx, ASUS A8V => EPOX nforce 4). So I have a water cooling system with a big heatercore and 2 fans on it. However after starting my computer the cpu temperature slowly rises to 55 degrees or so and just sits. I haven't stress tested it yet, but I did re-seat the waterblock and now the temperature stops arount 52C. My video card idles around 55 now. Before I upgraded my processor used to idle at 32 or so and the graphics card would idle at middle 40's. So what do you guys think? My ideas:
-need to re-seat the waterblock again
-pump flow problem?
-radiator fans not high flow enough? (the gtx actually added THAT much heat to the system)
-motherboard just reads high temps?
I did just refill the system after installing the new video card so its possible there is still alot of air bubbles left that are reducing the effectiveness of the water cooling.
Anyway I am going to try to test for some of the stuff I mentioned when I get home, but for now I am sort of looking for possible causes. Thanks
-pump flow problem?
