cpu temp not showing up
FordFreak
333
I can't get the cpu temp to show up anywhere. I've tried mbm5, the newest asusprobe and it also doesn't show up in the bios settings. I had version 1009 and am now using 1004b. I had to change the bios for another reason earlier today so I decided to check and it still didn't show up. a7v266-e, 1.4 t-bird, windows me.
Iron Woode
31,294
12,817
do you know how set up MBM? Sometimes it can be tricky.
I checked the site and found your board.
Primary sensor chip: AS99127F
case sensor: Asus 1
cpu sensor: Asus 2
Is there any pc health readings in the BIOS? can you see your temps there?
Iron Woode
31,294
12,817
Originally posted by: FordFreak
It doesn't show up in the bios either.
i don't like the sound of that.
Maybe the board is defective?
Is that the correct board? Maybe your board is not what it is supposed to be?
Ask the seller or Asus about this issue. Maybe they know something you don't.
